THOMAS'S WEB SITE
Cherry BX-2
Diverting Pulley Assembly
I had to do the Plate for the diverting pulleys over again. Setting up the correct angles is more demanding than expected. Bending and shaping the 3mm aluminum is not an easy task. Hope it works out with the second try.
Minor Adjustments
Cherry BX-2 Home
4021
Avionics/Instrument
Electrics/Instrument
176
306
Horizontal Stab.
Prebuilding Hours no
Projectinspection
Retractable Gear
97
252
Seating
Stand
Tank
60
Vertical Stabilizer
Wing Loading Test
Workshop
